Originally Posted by jza80rz
"The diagnostic trouble code can be read by the number of blinks of the malfunction indicator lamp when TE1 and E1 terminals on the data link connector 1 or 2 are connected. When 2 or more codes are indicated, the lowest number (code) will appear first. "
i dont have the data link?
If you've got an mk4 supra, you've got a data link
connector. It's below your steering wheel, partially under the dash, to the left (on us-spec mk4s).
