I could use some help
I bought a 87 supra ma70 has a 7mgte but no boost gage just a volt meter does this mean this car did not come with the turbo. I also rebuilt the motor,pistons,rings,rods, all new gaskets, head bolts,bearings,new intercooler kit, new radiator,new timeing belt,cam gears,water pump ect.
Now I removed the cam sensor and now can't seem to get the timeing right valve timeing at 0 tdc and my timeing needs to be at 10 btdc with the E and T1 shorted out the car will run but very high idel and I can get to 10 btdc however can not put bolt in due to the slot not over hole I have pulled out cam sensor out to rotate but can not get bolt to line up with the slot is there a way to line up cam sensor like a distrubeter you line it up with #1 spark plug. Also is this car supose to have an EGR my motor as a plate over where one would go. and there is no charcoal can. Maybe im missing things I dont know about. both vac lines are pluged on intake. would a pic? can any one help?
