Old 04-06-2009, 11:43 AM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by jza80rz View Post
I know but i dont have the "thing" to plug into it so i can read the codes... nor can i get my hands on one.
You don't need to plug a "thing" into it. Just bridge the two pins indicated with a wire or a paper clip! That's what the article means when it says:
"2. Connect terminal between TE1 and E1 of data link connector 1 or 2."
(if you needed an OBD-reader, the article would probably have mentioned that. )
Life begins at 30psi.
