Old 04-08-2009, 12:57 AM   #2
suprabahamut
Someone probably put a turbo motor in it or put a turbo on it and the timing cover. If it has a distributor it is a non turbo motor, the turbo came with a coil pack type ignition. There is 3 coil packs on the top of the engine that controls 2 plugs each, I think it is the waste spark type. Do a search on the internet for the 7mgte engine and look at some pictures see if it looks like yours. They are both the same motor though just the turbo came with a different spark type and lower compression I believe, I could be wrong though.
