I use Valvoline dura blend, it was around 6 dollars at auto zone it was about 5 dollars more for the mobile 1. It works fine for me. Check to see if your differential is a LSD, you have to buy special additive for it if it is. For filling it use a suction gun and put it in till it runs out the fill hole, after you drain it.
