Thread: idle stuck
Old 04-08-2009, 02:49 AM   #3
midwestmk2
midwestmk2's Avatar
I would also consider checking the inside if the throttle body..Some times build up of crap will cause it to stick open more than normal causing a high idle..Im also seconding the timing mentioned before..
