The Allen socket is 5mm
According to the instruction sheet that came with mine, see below:
With the ARP moly lube, the final torque should be 80ft/lbs.
With motor oil, ARP recommends 120ft/lbs with 30wt oil. However, ARP recommends using their moly lube, not motor oil, due to "higher friction on the studs as well as inconsistencies in the clamping force of the fasteners when motor oil (or low quality lubricant) is used."
The normal exhaust stud stops short of the hole depth by about 3/8 inch, some owner’s have used M10 x 1.25mm threaded rod and cut them to length to gain about 5 more threads in the hole.
I Heli-Coild mine, bit hesitant when it came to tightening up the nut though, I've had a few on previous heads pull out.
