By the way Nate car looks nice. On the subject of your question I have been there done that and Nate has to it would be easier to buy one that has already done the swap much cheaper. I will honestly say I bought my car for 1400 and invested a lot into it to go 1J on one hand it is worth it on the other it would be easier to start with a 89+ than with a 87 because of the differing mount issue. Another question I have for you is how mechanically savy are you because if you have someone do it for you then they are going to litterally rape you in the butt with a pine cone. The labor involved is decent and most places will charge 50 dollars a hour or more. Once I had all of the parts for mine it was a a few days worth of work in itself.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
