wont work
no the ecu from a non turbo will not work with the turbo engine. the injectors that r used in the two are different,and the engine compression is way off, oh and the reason it happen is because from the factory the use the wrong type of HG u must replace with metal HG for longer life, i would replace piston rings and have engine honed if ur going to keep it factory
