I'm having a little bit of a similar problem with the smoke right now. I just bought a running and driving 89 turbo for $800. What is getting me is that the engine is running strong with no lag, and it actually runs at a decent temperature. The only time smoke comes out is under acceleration, and maybe a little puff at idle. Any Ideas on if it might be an easy fix?
The seller had a HKS controller wired into the ECM which I removed and that helped an idle problem. I'm wondering if the ECM got messed up by the installation.
