Originally Posted by slayer8925
Oh alright thanks for the great advise! and ya i'm pretty sure i'm going to purchase a TT, however i'm probably going to import the RZ (Manual transmission) from Japan so it will be RHD. Just another question, i'm not sure if it's possible but can you get 1000+ HP with an RZ(manual transmission)? Do you have a suggested setup if it is possible?
I'm not 100% sure, but my best guess is yes, I believe that you can build a 1000hp+ setup with the RZ. If you mean 1000hp at the crank (850rwhp), then you'll need (in no particular order) a 72mm single turbo kit, a 100 shot of nos, some 272 cams, an AEM ecu, a fuel system with 850cc injectors, an intake (eg VirtualWorks) & throttle body, c16 race fuel, a twin or triple disk clutch, an fmic, and lots of dyno tuning. To put the power to the ground, you'll need some wide rear rims (eg. 11.5" wide), with some great drag radials, r-compound road race tires, or drag slicks. I'm pretty sure that's the most of the items. I posted a similar list on this thread:
http://www.toyota-supra.info/forums/...ond-supra.html
