Thread: 1jzgte Swap
Old 04-25-2009, 01:45 PM   #17
supradaddy0803
supradaddy0803's Avatar
The wiring for the 1JZ isn't that hard really as long as you take the time like I did and put in new harness plugs instead of soldering the connections for the four plugs you have to replace. I just bought some harness plugs that had enough pin holes to work and then bought the pins and did mine that way. As for the main engine harness you don't have to extend it you can always use the tuck like most people do it helps keep the integrity of the original harness.
1987 supra NA 5 speed
1JZGTE swap
Tokico pillow blocks
HKS type 1 turbo timer
Walboro 255 fuel pump
JZA70 Front end mod
