Originally Posted by Curtis
What about the single turbo's? How bad are they?
Sorry about all the questions but i don't have 30, 000 for a tt.
My friend has an 88 mk3, with a 7m-ge non-turbo, can he put a turbo on it, possibly tt?
Single turbo upgrade kits are great, especially on an engine designed for forced induction (like the 2jz-g
te).
Any engine can be 'upgraded' to handle forced induction, but it won't measure up to an engine that was specifically designed for it. For example, you can lower the compression a bit by using a thicker headgasket...but that changes the shape of the combustion chamber which negatively affects the engine's performance. In theory, you could take a 2jz-ge, change the pistons, mount oil squirters inside the block, and port the head to better handle the forced induction...but doing all of that properly (including reassembly) would probably cost about $4K or so. Add to that the cost of the single turbo kit, plus installation, the upgrades to the ignition, fuel system, brakes, suspension, transmission, and differential, and you're looking at a LOT more than the $ it would have taken to get a TT in the first place. You may not have the $ for a TT right now, but work hard for a few more months and you'll have the car you know you really want right from the start. Just mho.
