Originally Posted by 87mk111
nevermind, I was thinking it would cost around $2k. I guess I'll just turbo the 7mge. By the way, it's a 5 speed.
Buy a *7mgte*, unless you plan on buying everything exactly down to the needle, 7mge's don't have the oil sprayers in the block, trust me you want those. Other thing is, you will need to rebuild the engine if plan to turbo it, and usually that requires you to remove it, so why not swap it with a 7mgte.
