Thread: idle problems
Old 04-28-2009, 01:21 PM   #1
btwilson86
Super Moderator
btwilson86's Avatar
Can't help you with the 71 code, but that 51 code is most likely a throttle position sensor out of adjustment, causing your high idle. And for future reference, you shouldn't need to adjust that screw on the throttle...
Check here to set the TPS
