Thread: idle problems
Old 04-29-2009, 01:09 AM   #5
88 supra turbo
88 supra turbo is on a distinguished road
I finally broke the bottom screw loose on my tps and adjusted it. I had good results out of it but I let it sit for about 2 hrs and went back to start it and it stayed around 1400. It was fully operating temp. so I starting taping the tps and the idle kept coming down. I guess the switch inside is bad. It seems like it starts smoking when I push the throttle at low idle. Do you think maybe the dashpot not set right could cause this smoke on deacceleration. When it starts smoking it throws alot of water out the exhaust. It will cover your hand. Do you think I need to replace my tps.
88 supra turbo is offline   Reply With Quote
