Old 04-29-2009, 08:01 PM   #1
Bruno Molly
Bruno Molly is on a distinguished road
Default Couple of MKIII Questions......
My son is putting his 89 MKIII 7m-GTE, back together in AutoTech class after it was torn down a bit to replace the tired stock CT-26, Exhaust Manifold Gasket, VC Gaskets, and all the oil seals in the front of the engine as well as the timing belt. Its back together, runs great. My question is there is a small hose on the bottom of the Accordion hose after the Airflow meter. Its about 12mm thick of so and about 8-10 long and bent @ almost 90 degrees upward at the end like it should plug into a valve or something. I can't for the life of me figure out where this hose connects. It still has a spring clamp on it. Its larger than the typical vacuum lines but looks like a small fuel line type design. Where the Heck does this thing go? Also, one of the Power steering hoses is leaking at the crimp...Where is a good source (Other than my local Stealership) to get replacement power steering hoses?
Thanks in Advance
BM
Bruno Molly is offline   Reply With Quote
