Okay, question... was your ECU toast due to an internal failure, or did some other part of the wiring harness fry it? Because if a wiring problem somewhere else in the harness caused it to go out, and that wiring problem wasn't fixed during the repairs, then that wiring problem could still be causing you problems. Up to and including frying your new ECU.
