Yes ABS was an option on all MKIIIs, I live in Arizona and here I have only seen 1 or 2 without ABS. As far as doing a 7MGTE swap get a low milage front clip. This will give you everything you need to do the swap. Just buying and engine set will only get you half the parts. You will still need a down pipe, intercooler pipes, an intercooler, the stock oil cooler, as well as power steering lines and overflow tank. All of these are parts that are different and needed to do the jod right.
