I'm exhausted. Spent most of the day working on the car again. Took the gas tank down to remove the in tank fuel pump. Going to run a Holley external fuel pump & pressure regulator. Mount it right next to the tank where the rear exhaust heat sheild was. Won't be needing that shield, I'm going with sidepipes. Extended the fuel pick up tube with a clamp and a piece of hose. Will have a filter mounted prior to the pump.
Wired up the electric pusher fan, the starter cables, power for the accessories and ground cables. Bolted the starter back on. Bolted the exhaust headers on. Took out the spare tire. Cleaned up the garage.
Tomorrow, bolt on the fuel pump and pressure regulator. Screw in the spark plugs. Unbolt the flywheel to torque converter (2500 rpm stall). Fill the engine with oil and antifreeze. Tighten up the alternator belt and wire it up. Spin the oil pump with the oil pump primer. Install the distributor. START IT UP!
Only things left to purchase to make it driveable is the driveshaft and the rest of the exhaust. Sooooo close, I can't wait. Just in time for summer.
