Thread: 7mge to turbo
Old 05-08-2009, 01:58 AM   #4
masterghost
masterghost is on a distinguished road
7MGE NA-T can u say sleeper! : ) Well thank for your guys imput. i found the spot where the oil feed flang goes on the block and there is a tapped spot on my pan thats plugged already for an oil return line. As for the 1jz idea from what I've seen thats just a preference because people will swear both ways about the 7m and 1jz for why ones better then the other. The motor in my car will be fully balanced and port/ polished. It will also have turbo internals and all ARP hardware. I have a upgraded ct26, turbo manifold, rps cyborg flywheel, rps clutch and titanmotorsport 2mm head gasket for my car. My heads completely brand new i bet it will be cheaper then swapping a turbo motor in my car that has a bunch of miles on it and not knowing if the head gasket is good or not when i buy it. The motor swap to me isnt worth it when i can have a new rebuilt motor in my car with no miles.
masterghost is offline   Reply With Quote
