Old 05-08-2009, 03:19 PM   #6
Klein32
Klein32 is on a distinguished road
Originally Posted by mirage83 View Post
Is when you change the oil the only time you check for coolant loss, or is something going on when you change the oil which causes you to lose coolant?
Dune is right, you may have or be working on a bhg. Do yourself a favor and run a Block Test to see if you've got CO in your coolant.
No i check the coolant every week or so, but the only time i need to add any is around oil changes, i have just replaced my HG about 10,000 miles ago with a metal one. i checked all of my wiring and its still doing it, i think i may just flush the system and see what that does, its about time to do it anyways.
thanks for the help.
Klein32 is offline   Reply With Quote
