yea i just found that...the 2jz is a non-interference engine....super...are you sure the headgasket for the mkiv is bad? ive only heard of problems for it for the 7m not the 2jz...for the 2jz i heard the head is just as good as teh bottom end, as for looking for a supra...just look for the basics...like rust, leaks, boost leaks, definitely take a test drive...u usually dont find stuff just by looking at it...check the compression...not sure...but i think the compression on that motor should be about 140-147....i think ill have to double check on that, all the cars were the same that were sold here in america.., if i were you i would get the turbo...but then again some prefer the n/a route...i know some people with 11 sec n/a supras....so keep that in mind
Now: Saving for an MKIV
Broken Rides:
