i used to have the manual controller and would hit spikes once and a while
here's my BOV in between the two rubber elbows .
i think i use the same boost gauge and it's tapped into the upper intake
here is a pillar pod photo
notice the whacked since day 2 stock temp gauge .. how would you feel driving with that gauge sitting where it sits sometimes pegged then all the sudden she'll drop to normal . damn car isn't even started just the IGN to ON in this picture.
i replaced all stock hoses wiith hose from hose techniques
hose tecniques
you can get a kit to replace your whole setup
even the water bottle up front and painted the formed elbow pointing to the ground.
FCO is hit by volume as well as lbs. and i think the position of the sun and moon
days like today are tough for boosting wicked high humidity over 70% and air pressure is 29.92 Hg whatever that is all i know is it's harder to make boost on these august days until night time B)
