my bad i assumed you were turbo ( i should've asked) no you won't need a turbo elbow then. i'm not sure if its still called a downpipe if its n/a cuz it connects to the exhaust manifold not turbo so i'm not sure. my first supra was n/a and all i did to that was cut the cat off put in a test pipe and get a muffler and called it good. can't remember if n/a exhaust is 2" or 2.5"? i wouldn't worry about the exhaust then until you go turbo.
