Thread: Confused
Old 05-21-2009, 07:56 AM   #2
86.5 7MGE
86.5 7MGE's Avatar
Cool
I would check the oil just in case to see if it has any milky color to it...the 7M motors have a bad rep for BHG do to poor torquing by the manufactor... And the motor is great it will still run like a champ even though it does have a BHG...If not, then it could be a rich mixture causing the problem...also you can check your plugs to see if they are brown in color this will also let you know if you have a BHG, they should all look similar white and not brown if you do pull any with brown on it then that cylinder has been envaded by coolant due to a BHG...if I'm wrong I'm sure someone will correct me.
Cold Air Intake
MIZU Aluminum Radiator
Ralco RZ Underdrive Pulley
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Techna Fit Brake lines
Clear Corner Turn Signal Lens
Projector Head Lights
Evo Fog Lights
Evo Body Kit
Soon ---> 3'' Exhaust
