Originally Posted by 86.5 7MGE
I would look under the dash in the mess of wires to see if you can find the other end of it; also try looking on the side where the fuse box is. I sure that the wire would be under the dash some where. The CSS is used for your cruise control if it's not hooked in your just not goining to be able to engage your cruise control.
Yeah I ripped the Cruise control out about two years ago, it was broke anyways. Which one is the connector for the cruise control? thanks
