Thread: Need some help!
Old 05-23-2009, 03:27 PM   #1
86.5 7MGE
86.5 7MGE's Avatar
Cool
Originally Posted by Tundo View Post
Yeah I ripped the Cruise control out about two years ago, it was broke anyways. Which one is the connector for the cruise control? thanks
They both are for the cruise control. What happens is that when you press the clutch it detects that the clutch is being pressed and turns off the cruise control. And the other detects when the clutch is in it's normal position (not pressed) and it allows you to turn on the cruise control. The CSS is the one in the back of the clutch. Hope this helped you out some what
Cold Air Intake
MIZU Aluminum Radiator
Ralco RZ Underdrive Pulley
NGK Wires and Plugs
Hi Flow CAT
MR Muffler
Super Coil
Techna Fit Brake lines
Clear Corner Turn Signal Lens
Projector Head Lights
Evo Fog Lights
Evo Body Kit
Soon ---> 3'' Exhaust
