Well this past week I got around to changing the power steering pressure line. It took a week or so just to find out the leak was coming from there! That was the biggest pain, which was surprising seeing as I thought removing the old line and putting in the new line was going to be a pain. Whole process took about 3 hours, the line itself cost $54.00
While I was in there I had to remove the intake hose to the Turbo and the line from the Intercooler to the intake itself. Upon removing them I was surprised to find some traces of oil. Here are the pics:
Removing the pressure line, oddly enough the whole assembly came out together... putting that back in was fun
Hose from the intercooler to the Intake itself, its hard to see but there is a small amount of oil in the hose. Is this normal?
Another Shot
Intake shot, the Oil is hard to see here
Turbo, notice the oil on the lip, is this also normal?
I checked the turbo, everything is spinning as it should and I don't see any oil leaking directly from inside. I also checked around the outside of the turbo itself and nothing out of the ordinary. But I am noticing that I am going through oil like crazy, while I was fixing the powersteering line I noticed two oil lines underneath that are leaking and those are next to be replaced, but I'm not convinced they are the main problem. I use 20W50, I would think that would be right for this car. Although I am fairly new to Turbo'ed applications so my query is, Because of the Turbo do you get a lot of burned off oil from regular daily driving? Are these cars known to burn oil like this?
And secondly, Should I be concerned about the oil in the intake lines and on the lip of the turbo?
Thanks,
-Ryan
