About the exhaust leak !
The first thing you want to do is find out exactly where the leak is !
Usually new gaskets and donuts will fix the problem.
You may have lose bolts or a hole in the exhaust. if thats the case you will have to cut and replace the part that is leaking.
But since i dont know where it may be leaking, i cant give you more info. sorry !
