Originally Posted by TT97
Well, what is the most RWHP i can squeeze out of a t67 turbo with pump gas or methanol injection????
And can u also explain how a methanol injection kit works?? and how its used up and costs for it?? Thank You
With pump gas and methanol injection, you can expect about 600rwhp out of a T67-equipped us-spec 2jz-gte, through a 6spd. This assumes the turbine a/r of your T67 is .80 or bigger.
A meth injection kit sprays methanol into the charge-air piping when you boost, so your (only) 93 octane fuel doesn't lead to detonation at moderate boost levels (eg. 24psi). You'll need a
high-end meth injection kit - something made to go on a civic won't cut it.
