ABOUT THE ecu ISSUE !
You can try a new ECU but to be honest I would check for a boost leak or injector seal. If it wont accelerate properly and its backfiring, could be a couple of things... bad fuel pump, faulty TPS or CPS, clogged fuel filter or injectors. I would start there first !
