Old 06-04-2009, 12:14 PM   #2
IHateHacks
IHateHacks's Avatar
Brake line is bad.
If the hole is in a rubber line the fix is quick and easy, if the hole is in a hard metal line, you will have to fabricate your own.
Brake fluid needs to be changed once every year or you risk impurities causing damage to the brake system.
