Don't need to rewire them. Pull the TEMS motors off the top of the shocks and you'll see the shock adjustment shaft. It'll have a slot in the top for the adjustments and you'll probably see settings 1-5. Use a standard screwdriver and turn the slot on all your shocks to "5", and just don't put the TEMS motors back on. That's the stiffest setting for your suspension.
That's all there is to it. GL.
