7MGE ECU problems
I have a 7mge in my 89 runner... For the most part it seems to have run fine for about the last year... On may long it started to sputter a bit at lower rpms and the tach and a couple other gauges went whacky. Now I can hardly drive it it sputters so bad. My check engine light doesn't work either even from the pin at the computer it doesn't ground the wire. My only guess is to try a new ecu. Oh ya it doesn't seem to adjust idle or anything when its cold either. Any ideas?
