check it out my supra is an 89 and the alarm is all haywire as well when I took out some of the fuses it would start its the same fuse for the radio...if that helps take it out it will start then put it back in while running now your radio will work I hate it but if its too much of a hastle for you car quest will take out the stock alarm for 150$ for you an
d problem gone...
