Thread: tranny swaps
Old 06-19-2009, 11:03 PM   #1
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by Doug99 View Post
Would anyone happen to know if you can swap an automatic into a 6 speed in a 98? If anyone could help that'd be awesome thanks!
Yes. If you mean an auto from an mkiv tt, it's a straight bolt-in. Of course, you'll probably want to get rid of the clutch pedal, and you'll need to use a different ecu. I'm pretty sure there's a difference in the wiring harness too so you'll either need a full harness from an auto, or you'll need to do some custom wiring to wire the auto-specific connectors up to the ecu.
Life begins at 30psi.
