Originally Posted by Durandal
So after having my supra for a year, I want to take it to BPU. It is currently stock with a lowered bilstein suspension, fujitsubo exhaust and turbo timer. Does anyone have experience with going BPU with a JDM because I have heard some parts don't work on JDM. Is the following all I need as far as parts?
HKS Speed Delimiter
TRD speedo
Cold Air intake
Hard pipes
upgraded temp sensor
wider rims and tires
bigger brakes
Any help appreciated! Thanks
No speedo necessary for BPU. No cold air intake necessary for BPU. No hard pipes necessary for bpu. Bigger brakes not necessary for bpu.
You will need:
- A way to limit fuel cut (in the us-spec, this is done with a GReddy BCC)
- A downpipe to eliminate the oem catalytic converter
- a way to raise the boost (the clamp-mod should work just fine).
