Timing belt is gone if the engine turns over but the cam's aren't. Not too bad a fix, but you'll need to be sure about getting the timing right aftward. It doesn't have to be off by much to keep the engine from running, and that goes for the mechanical timing (10 deg BTDC IIRC) as well as the CPS alignment.
