Old 06-26-2009, 04:45 PM   #2
TurboSupera
TurboSupera is on a distinguished road
Originally Posted by ddmcse View Post
there is no "air filter light" you might be talking about the low coolant in the reserve bottle light .
it's on the left of the dash
some people call it the "bird cage" light ," museum light"
add coolant to the plastic bottle next to the drivers side head light
Ditto. And if this keeps happening make sure you figure out why. I thought I was heading for a blow head gasket....but luckily it turned out that the tube from the radiator to the reservoir was not tight, enough and slowly leaking coolant. It turned out I guess, the clamp was holding it down tight enough.
TurboSupera is offline   Reply With Quote
