Hey bud, you should never use starting fluid on a Supra !
Too much danger ruining the AFM.
Have you checked your fuses?
did you make sure you have the fuel lines in the right place?
check the EFI relay?
when you turn the ignition on do you hear the fuel pump cycling on then off?
Do you have pressur when you cycle on or off?
you should have about 37 to 44 psi to the fuel delivery rail !
If not check all your fuses first. check for fuel leaks....
Let me know once you have done these checks
