Old 07-01-2009, 06:37 AM   #1
mirage83
Small vacuum line on the bottom of the accordian hose goes to one of the two vacuum tubes on the switch on top of your PS unit (the pump, not the reservoir). Doesn't even matter which. IIRC it adjusts the idle up when you turn the wheel while at idle/dead-slow speed.
As for your trim you can strip and paint/powder coat it, or replace it. It's still available through Toyota.
