Old 07-02-2009, 12:48 PM   #2
pwpanas
Supra Owner
pwpanas's Avatar
Originally Posted by Durandal View Post
I have an MKIV, right after I posted this I went back and checked the fuses and relays. The main EF1 replay for the ECU was bad so I swapped it with the fog light relay.
Thank you for updating us with the solution to the problem your Supra had...and congratulations on your successful troubleshooting! How did you narrow down the problem to a relay? I guess I've been pretty lucky that I've never had one go bad on my mkiv...
Life begins at 30psi.
