07-02-2009, 01:00 PM
#2
Supra Owner
Originally Posted by krahs912
i have a 95 supra tt with code 14, 35 it has a rolling idle and pings badly. any one seen this or have any idea what it could be? Thanks!
DTC No. Circuit Diag..______Trouble Code Detecting Condition______Trouble Area______________________________Normal Mode Test Mode Memory
14______Ignition Signal______No IGF signal to ECM for 4~7_____________· Open or short in IGF circuit from igniter to ECM___ON__________n/a_______Yes
_________________________consecutive IGT signals with______________· Igniter
_________________________engine speed less than 3,000 rpm._________· ECM
35______Turbo Pressure
________Sensor Circuit
Based on this info, my first guess is that the problem may be in your Supra's primary wiring harness. Has it been disconnected from the ecu recently? If so, it may need to be removed and re-seated.
Life begins at 30psi.
