Originally Posted by SUPRBAD
They both run at the same time. They are mounted on seperate tubular exhaust manifolds.
Based on some quick research, I'd estimate that setup would be good for about 680rwhp at mid-boost levels (mid, for an mkiv is 24psi-ish) on race fuel (of course), with the oem cams, through a 6spd. If you upgrade the cams to 264s or 272s, and run high boost (32psi+) with very high octane race fuel you'd probably get close to 800rwhp through a 6spd.
As far as response, you won't see much useable boost below 4000rpms.
Of course, these estimates all assume your engine is in good shape.
FYI: Here are a few of the links I used for my estimates:
http://www.tweakit.net/shop/product_...oducts_id=5888
http://www.elitedubs.com/index.php/t....msg18582.html
http://www.ztechz.net/id1.html
