Water leaking everywhere? Can you be a little more specific, try and identify just where it's coming from? There's a BUNCH of lines running around the engine which could be culprits.
If you've got white smoke coming out the exhaust, that's probably water entering the cylinders. BHG.
As with the water, exactly where is oil leaking from the engine?
The oil on your spark plugs, is it in the spark plug valley where the plug boots are or on the business end of your plugs?
Sorry for all the questions, but it'll make it easier to figure out what you've got going on.
