Do not use block sealer!!!!!!!!!!!!!!!!!!!!!!! Temp fixes only make problems worse. Second a little water in the cylnders from the spark plugs is not bad, it might clean the pistons and valves a little. Too much water will dround the plugs. If you have smoke coming out the exhaust check you oil is ther water in it? Check you coolant is there oil in it. If you answer yeas to either of these the you got a blown head gasket. Get a GReddy metal head gasket and ARP head bolts or better yet head studs.
