Old 08-14-2005, 04:16 AM   #3
Poodles
Poodles is on a distinguished road
Yep, same engine, but I hear the head is a bit different. Keep in mind that the Supra engines are different for the Turbo and N/A, the turbo engines are built for boost. It appears that a 2JZ-GTE would bolt right in, but mounting the intercooler, and running the piping, let alone the ECU, would be a bit hard (but well worth it). Putting turbos on the stock engine in that car I wouldn't push more than 5lbs of boost because of the compression...
Poodles is offline   Reply With Quote
