Originally Posted by 7mlove88
I just checked that out and the O-ring on the CPS is not damaged and looks fine..but the plastic cover of the CPS and the plastic gasket within is cracked and completely destroyed...so despite the 0-ring retaining the oil within the sensor could that plastic cover & gasket be the problem?
yeah you probably have to replace the gasket. And check the hoses if theirs any split it'll need replacing, I've had to replace numerous ones.
