Originally Posted by 86.5 7MGE
That's a sweet set up...currently I'm fixing all of my minor things so that my car can get it's hp back and I'm saving to put a turbo on my as well. What I would like to know is what all did you need to do to get it ready for a turbo. And do you have any problems with or during the NA-T application. I was thinking of going with a small turbo so it would be less chances of blowing my engine up what do you think?
Well really if you run any ammount of high boost on any turbo it will blow as the compression is to high. But if you use a stock turbo you should be fine running up to 10 lbs of boost no problem I believe. But you'd definately need all new piping, ecu ect to do this. I'm sure someone parting out a car you could just ask for it all and get a price on it though.
